16 years agoQuartus II should give the same results with the same inputs on the same OS. (Linux and Windows give different versions, but just a seed affect). There is no "random" input to the process. I rely on this all the time and see it work. (On the flip side, the smallest change, such as changing the name of a signal, could give you different results).
You might want to do a diff on the reports. The first one, .mao.rpt, is what will probably show it, and if there are any differences, it would make sense.
