11 years ago
ID for each module from the for generate
Hello guys,
I instantiate a bunch of the same module with a for generate statement.
I dont know how to store the hcu_id of the module( I need it in an another part of the system); with ID I mean the
variable i of the for generate. I would need something like a constant input equal to the i variable of the for generate.
Any ideas?? Thanks
    not quite sure I get the problem? it would be easy to pass in the loop value into a signal of the instatiation inside the generate, giving each instance access to it's ID number.
    Why not post some code so we have a better idea of what you are trying to do.
    Ok this is the top entity. I instantiate this module like this:
    g_upd_req_conn : FOR i IN 0 TO MAX_H_TILES - 1 GENERATE
    u_upd_req_conn : ENTITY work.upd_req_conn(beh)
    PORT MAP(
    rst_n => rst_n,
    clk => clk,
    ID => ???
    END GENERATE g_upd_req_conn;
    I need to give an ID to each module equal to the variable i, like a constant input. Any ideas?
    --- Quote Start ---
    PORT MAP(
    rst_n => rst_n,
    clk => clk,
    ID => ???
    --- Quote End ---
    if ID is integer:
                PORT MAP(
                    rst_n                    => rst_n,
                    clk                      => clk,
                    ID                      => i
