12 years ago --- Quote Start --- Hi I am trying to fix timing violations on my design, IC delay between global clock buffer to IOBUF is causing a negative slack of -1.698. I have tried to instantiate regional clock buffers instead of global clock buffers then i am running in to data path delay since option "FAST_INPUT REGISTER ON" to data ports is getting ignored. Any suggestions how to fix this. --- Quote End --- Are you driving the clock off the chip? More information here would be helpful, such as the output of "report_timing" for this path.
