AUden
8 years agoI2C implementation in VHDL
Hey ! i am trying to implement i2c protocol using VHDL Language. In my Case Master is Arria V FPGA & Slave is ADV7182. The issue what i am getting is Acknowledgement. I am getting not Acknowledgem...
Tricky
8 years agoI suggest not using SCL_CLK as a clock. It is very slow compared to the FPGA clock and wont be a very good clock. Use the FPGA clock for everything and use the SCL_CLK you generate as a clock enable for the I2C registers.
