DMART19
7 years agoI would like to know if the EPM3032ATC44-10 would be compatible with EPM7032AETC44-10N. We want to program an old compilated project generated by Quartus II for the series 3000 into the device of series 7000. Thanks in advance.
Nooraini_Y_Intel
7 years agoHi DMart19,
Both MAX 3000 and MAX 7000 device are different family device thus the architecture are different. There is no direct answer to this compatibility question without doing hardware testing. You need to compile the project design, program the .pof file into MAX7000 device and test/monitor if the design does actually work/function as expectation or not.
Nooraini
