JKoty
6 years agoI would ask for help with error message when .qar file is generated.
Hi I would ask for help with issue. I have Quartus Pro edition 18.1 build 222. When I run command: project_archive c10_pcie.qar -include_libraries from .tcl file system return me error message: ...
JKoty
6 years agoHi, I removed almost all from the our project and there is only part of our framework and design only with PCIe HARD IP. Inside archive is build project to save some time from your side. To reproduce our issue you need have all tools in Paths (We are now using Quartus Prime Version 18.1.0 Build 222 09/21/2018 SJ Pro Edition ) and run only target "Archive project" in impl/c10_pcie/impl.tcl. Now are UN-Commented ALL targets for case you would like to see all steps. We are run impl.tcl by type "make compilation"
I believe that you will be able to reproduce it.
Best regards
Jan
