11 years agobut i still confused about this part......
LIBRARY IEEE; USE IEEE.STD_LOGIC_1164.all; USE IEEE.STD_LOGIC_ARITH.all; USE IEEE.STD_LOGIC_UNSIGNED.all; -- This code displays time in the DE2's LCD Display -- Key2 resets time ENTITY DE2_CLOCK IS PORT(reset, clk_50Mhz : IN STD_LOGIC; LCD_RS, LCD_E, LCD_ON, RESET_LED, SEC_LED : OUT STD_LOGIC; LCD_RW : BUFFER STD_LOGIC; DATA_BUS : INOUT STD_LOGIC_VECTOR(7 DOWNTO 0)); END DE2_CLOCK; ARCHITECTURE a OF DE2_CLOCK IS TYPE STATE_TYPE IS (HOLD, FUNC_SET, DISPLAY_ON, MODE_SET, WRITE_CHAR1, WRITE_CHAR2,WRITE_CHAR3,WRITE_CHAR4,WRITE_CHAR5,WRITE_CHAR6,WRITE_CHAR7, WRITE_CHAR8, WRITE_CHAR9, WRITE_CHAR10, RETURN_HOME, TOGGLE_E, RESET1, RESET2, RESET3, DISPLAY_OFF, DISPLAY_CLEAR); SIGNAL state, next_command: STATE_TYPE; SIGNAL DATA_BUS_VALUE: STD_LOGIC_VECTOR(7 DOWNTO 0); SIGNAL CLK_COUNT_400HZ: STD_LOGIC_VECTOR(19 DOWNTO 0); SIGNAL CLK_COUNT_10HZ: STD_LOGIC_VECTOR(7 DOWNTO 0); SIGNAL BCD_SECD0,BCD_SECD1,BCD_MIND0,BCD_MIND1: STD_LOGIC_VECTOR(3 DOWNTO 0); SIGNAL BCD_HRD0,BCD_HRD1,BCD_TSEC: STD_LOGIC_VECTOR(3 DOWNTO 0); SIGNAL CLK_400HZ, CLK_10HZ : STD_LOGIC;
