XCui0
7 years agoI use recommend vhdl to instantiate alter ram. How can I add the sclr control to the code?
I include the sclr control in my code, but it will not connect to the sclr pin of altera_syncram. I tried to instantiate a ram ip, and enable the sclr, I can see that my sclr will connect to the sclr...
Vicky1
7 years agoHi Xin,
As I suggested in previous post , If you want to use Emulate TDP in your project then you have to fulfill the requirement as mentioned in user guide.
Another way is you can generate the HDL(*.vh,*v) file for Emulate TDP & then modify that HDL file as per your requirement, eventually you should verify it by writing testbench for that.
Vicky
