Hi Xin,
1. The code provided over here, having multiple errors,please provide code which has been compiled without error if possible provide project file(.qar)(Project menu-> Archive Project)
2. true dual port dual clock ram. From ip editor, it only supports two read/write ports with input/output clock, which means all input signal are registered by clock0, and all output signals are registered by clock1. In this case, my understanding is that all signals except q_a and q_b are using clock0, is that correct? -- --here output clock will control only the data output registers & rest of the registers are controlled by input clock.
3. We need to use a two port ram with independent clocks: port A is driven by clock0, ad port B is driven by clock1. --- You have to use Read/Write Clock Mode.
4. Is there any limitation to use true dual ports with independent clocks? --- Yes,this can be done using Emulate TDP dual clock mode & this option is available only if you select With two read/write ports and Customize clocks for A and B ports clocking method.
Refer the below user guide for more details,
Vicky
