RMees
8 years agoI trying to generate seriallite_iii_a10 example design. When I use Quartus Prime Pro the design is generated. When I use Quartus Prime Standard the IP Parameter Editor stops responding and I am forced to kill Quartus.
Only the ed_sim directory with sub-dirs aldec, cadence, mentor, synopsys and tb_components are created with a total of 24 files. I cant use Pro because I use IP that is NOT compatible with Pro. Usi...
AndyN
8 years agoAre you trying to use the same project file or do you have two separate copies for each tool version?
