13 years agoDear Dave
--- Quote Start --- The simulator does not know what you want for the initial value for Q. Supply an initial value for the signal, eg.,
-- Difining signal(s)
signal Q : std_logic_vector(25 downto 0) := (others => '0');
and it will work fine. An alternative method is to add a reset input and then add reset logic to the counter process. Cheers, Dave --- Quote End --- I did the way you told me and it worked fine!! Thank you very much and I'm soooo happy now because this had been bothering me like 12 hours...
