I have a problem with Quartus Prime 18.1 Lite Edition. More specifically, when creating a .vwf file for the Simulation Waveform Editor, a few lines within the file are quite wrong. Attached is a Word document with details.
Hi Vikas,
Thanks for the reply.
Perhaps I should have mentioned that I have always been clicking on the Restore Defaults button, right after setting up pin assignments, and prior to saving the file - Simulation -> Settings is unavailable before going through pin assignments, and is disabled before that.
The Restore Defaults changes the initial file name in those lines I highlighted from Waveform.vwf to <project name>.vwf (light.vwf in my example) but it does not correct the messed up paths.
When I described the problem originally, I was trying to point out that this erroneous path is created right at the get go when the Simulation Waveform Editor is invoked.
I should also mention that .vwf file appears to behave like a configuration file used for initial setup only. Changes to it do not appear to take effect until the Simulation Waveform Editor is closed and restarted.
Of course, since I do not know the internals, that too may be an illusion.
Rashid Beg
