17 years agoTo stop SOPCB from analyzing the IP library, you may need to write a simple wrapper HDL.
Or if you instantiate FFT IP in verilog, component editor may accept the top verilog code as is. As a matter of fact, since FFT IP has non-pure Avalon-ST signals, ex. multiple output data buses for a single sop/eop pair, you have to write a wrapper code to connect with other SOPCB components such as SGDMA...
