MCoop7
7 years agoI have a .JIC developed with Quartus 11.0 Jan 23, 2015 I am attemtping to create a new .JAM file. When I create the .JAM with Quartus 19.2 I get a failure when running .JAM on third party tool.
I have attached 2 files. H_777)IC33_Altera_03.JAM passes using 3rd party corelis tool. The other file I recently regenerated with Quartus 19.2 using the same .JIC and bsd files. I suspect somethin...
YuanLi_S_Intel
7 years agoHi Mark,
I am having issue in opening the file that you attached. Exit Code 6 indicates that the Device ID is not recognized, you might need to add that inside the JAM to fix the exit code.
YL
MCoop7
7 years agoOOps I forgot to mention the eps128 is in the .Jam file that's whats odd.
