I have a ep3c55 with a M25P20 configurator. What version if any can I use thats free to program the M25P20 with a hex file?
Hi MCoop7,
M25p20 device do not in any version of Quartus.
Another alternative I can recommend, you can use "Generic Flash Programmer" in Quartus 18.1.1std /19.1pro version and above.
"Generic Flash Programmer" enable user to define any 3rd party QPSI flash device in Quartus.
- MCoop77 years ago
I assume both of these require a license and isn't free?
- ShafiqY_Intel7 years ago
Yes, both of these require license.
- MCoop77 years ago
I downloaded 18.1 Prime Standard Edition I found a license I can use from our design group. I opened up the convert programming file window like above but I dont see the NEW Button I must be missing something still checking for updates.
Hi MCoop7,
"Generic Flash Programmer" only available on 18.1.1 and above.
Please update your Quartus to 18.1.1.
Below are the step to update the Quartus to 18.1.1:
- Go to link http://fpgasoftware.intel.com/18.1/?edition=standard
- Select the "Updates" option
- Follow the "Download and install instructions."
In addtion, to check your current Quartus version:
- Open your Quartus
- Go to Help > About Quartus Prime.
- You can see whether your current Quartus is 18.1.0 or 18.1.1
- MCoop77 years ago
I think I have the m25p20 entered correctly? I am surprised the software filled in the Initialization/program/erase/verify flow charts without any input on my behalf. My question though is I see some commands that dont match the m25p20 datasheet and a couple for which i have no clue where or what they are? see below. VCR Command 0x81? EVCR Command 0x61? These are not even in the Command set for m25p20?
