BRIANNN's avatar
BRIANNN
5 years ago
I can't install USB Blaster driver on Windows 10
I have some troubles when I try to install the driver for USB Blaster (the first generation, not Blaster II). I'm using the 10 and Quartus lite 20.1 software. I also find the solution on this page. Why does the Intel® FPGA Download Cables drivers installation fail on Windows* operating system? But when I install the Patch 0.02i and Patch 0.02stdp under the Quartus install location. It cannot find the Quartus pro software and Quartus Prime Standard Edition Programmer and Tools. I'm not sure I did the correct steps.
I have check the certification of the drivers, it has expired. Is there any newest version of the drivers?
Regards.
  • Sorry, i am confused. Do you mean you cant find the quartus path as per steps 8?
    8. Enter the following path for the driver and enable include subfolders
    - <Intel Quartus Prime software install directory>\quartus\drivers or
    - <Intel Quartus Prime Programmer install directory>\qprogrammer\drivers or
    - <Intel Quartus Prime Programmer install directory>\qprogrammer\quartus\drivers
  • YuanLi_S_Intel's avatar
    YuanLi_S_Intel
    • BRIANNN's avatar
      BRIANNN
      I mean, I cannot install the Patch 0.02i and Patch 0.02stdp in the Quartus lite.
      regards.
    • sofi's avatar
      sofi
      Dear BRIANNN,
      I've had the same issue and been trying for hours to install the patch. I already tried the solution posted by YuanLi, but can't seem to find the correct path. Could you please post the solution that worked for you?
      Regards.
