I can't install USB Blaster driver on Windows 10
- 5 years ago
Sorry, i am confused. Do you mean you cant find the quartus path as per steps 8?
8. Enter the following path for the driver and enable include subfolders
- <Intel Quartus Prime software install directory>\quartus\drivers or
- <Intel Quartus Prime Programmer install directory>\qprogrammer\drivers or
- <Intel Quartus Prime Programmer install directory>\qprogrammer\quartus\drivers
I have solve it. thanks.
- sofi5 years ago
Dear BRIANNN,
I've had the same issue and been trying for hours to install the patch. I already tried the solution posted by YuanLi, but can't seem to find the correct path. Could you please post the solution that worked for you?
Regards.
- BRIANNN5 years ago
I follow the steps in Why does the Intel® FPGA Download Cables drivers installation... . It's very important to choose the correct install path.
The path you need to choose when install the patch is a folder called Quartus, Which is the root directory of the whole Quartus software.
Hope this can help you.
Regards.
- Araa4 years ago
I have the same problem. Despite downloading the 0.02i patch in the quartus folder I always the receive the same error that the tools are not in the folder.
Can you help me?
