Loren11
3 years agoI can't get any output value of FFT IP simulation with NCO IP input.
Hi, I'm trying to simulate with fft ip with nco ip input. But I can't get any value on waveform.
I just made project with nco ip, fft ip and top module.
I add each .qip files on project.
an...
Kshitij_Intel
3 years agoHi,
As we do not receive any response from you on the previous reply that we have provided. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
Thank you
Kshitij Goel
- Loren113 years ago
I tried simulation with example of FFT IP.
I just made example design using Platform Designer and I added fft.sip and fft.qip file to project.
and I set fft_ii_0_example_design.v file to top module.
-> compile is ok (in Compilation menu)
I changed to RTL simulation and start but I failed simulation...
