Loren11
3 years agoI can't get any output value of FFT IP simulation with NCO IP input.
Hi, I'm trying to simulate with fft ip with nco ip input. But I can't get any value on waveform.
I just made project with nco ip, fft ip and top module.
I add each .qip files on project.
an...
Kshitij_Intel
3 years agoHi,
Can you please first try by giving a constant input to FFT IP and once it worked then feed NCO IP output to the FFT IP.
Also, You need make sure to add your testbench and dependent files in the script you are executing.
Thank you
Kshitij Goel
