weigaozu
3 years agoI can't generate an Example Design of Displayport IP using Quartus Prime Pro 23.1.
Always prompt for an error.
Info: dp_0: Creating design example Info: dp_0: Creating Core Qsys subsystem Info:...
ZH_Intel
3 years agoHi Wei Wei,
Thank you for reaching out.
Apologize for the delayed response.
Based on the information that you shared, it seems like this could be an issue with WSL patch on your operating system.
Allow me to clarify some items below:
Q1. You are running Quartus software on Windows environment, is this correct? May I know which version of Windows OS?
Q2. Have you install the WSL patch correctly on your OS?
Please ensure that the WSL installation and patch is installed successfully.
You may refer to below link for more information on WSL:
- Intel KDB Article - How to install the Windows* Subsystem for Linux* (WSL) on Windows* OS?
- Intel Guide - 2.3.1. Installing Windows* Subsystem for Linux* (WSL) on Windows*
- Install Linux on Windows with WSL
- Run Linux GUI apps on the Windows Subsystem for Linux
Q3. Other than the log you shared, is there any other error that appear on Quartus?
Hoping to hear back from you so that we can proceed for next step.
Thank you.
ZulsyafiqH_Intel
