BVola
6 years agoI am unable to program an MT25QL128 flash with the programmer-I get the error "Flash Loader IP not loaded on device 1". What's the problem?
I'm able to program the device from the command line: "quartus_pgm.exe -c Usb-Blasterii -m jtag -o ipv;arrinx.jic".
JohnT_Altera
6 years agoHi,
When you include programming both FPGA and flash then it will start to load Flash Loader into FPGA before programming the flash. without this you will observed that the Flash loader IP is not loaded.
May I know if you are able to reduce the TCK clock frequency to 6Mhz? May I know which Quartus version are you using?
