BVola
6 years agoI am unable to program an MT25QL128 flash with the programmer-I get the error "Flash Loader IP not loaded on device 1". What's the problem?
I'm able to program the device from the command line: "quartus_pgm.exe -c Usb-Blasterii -m jtag -o ipv;arrinx.jic".
BVola
6 years agoThe problem is ONLY with the GUI; as I said, it works ok from the command line. I generated the JIC file using File/Convert Programming File. See attached screen capture.
