BVola
6 years agoI am unable to program an MT25QL128 flash with the programmer-I get the error "Flash Loader IP not loaded on device 1". What's the problem?
I'm able to program the device from the command line: "quartus_pgm.exe -c Usb-Blasterii -m jtag -o ipv;arrinx.jic".
JohnT_Altera
6 years agoHi,
May I know if you are also seeing the same issue when you are using Quartus Programmer GUI? May I know how do you generate the JIC file?
