i am getting this error while creating any project? how can i solve this.
*** Fatal Error: Access Violation at 0X00007FF46343DB20
Module: quartus.exe
Stack Trace:
0x45da63: QAccessible::queryAccessibleInterface + 0x33
0x46403c: QAccessible::setRootObject + 0x153c
0x4652e9: QAccessible::setRootObject + 0x27e9
0xa4c0: CreateStdAccessibleProxyW + 0x1e0
0x39742: UiaReturnRawElementProvider + 0x1fed2
0x68619: UiaReturnRawElementProvider + 0x4eda9
0x37bfe: UiaReturnRawElementProvider + 0x1e38e
0xea7c0: UiaHasServerSideProvider + 0xa870
0x149adc: WindowPattern_WaitForInputIdle + 0x24d4c
0x37704: UiaReturnRawElementProvider + 0x1de94
0x37439: UiaReturnRawElementProvider + 0x1dbc9
0x22adf: SystemParametersInfoW + 0x24f
0x230bc: GetClassLongW + 0x58c
0xa2c93: KiUserCallbackDispatcher + 0x23
0x14d3: NtUserPeekMessage + 0x13
0x21bde: PeekMessageW + 0x1ce
0x21aab: PeekMessageW + 0x9b
0x132d77: QEventDispatcherWin32::processEvents + 0x1c7
0x83564: QApplicationPrivate::translateTouchEvent + 0x884
0x109cf0: QEventLoop::exec + 0x230
0x420e3c: QDialog::exec + 0xec
0x6471c: AFCQ_MSG_DISPLAY::internal_error_display + 0x1dc
0xe497: MSG_REPORT::internal_error + 0x127
0x1ee2e: MSG_INTERNAL_ERROR::set_talkback_xml + 0x11be
0x1f209: MSG_INTERNAL_ERROR::report_fatal + 0x179
0x4200: err_report_fatal_exception + 0x70
0x4499: err_report_fatal_exception + 0x309
0x3e316: Ordinal24 + 0x46
0x15b99b: UnhandledExceptionFilter + 0x1eb
0xdba71: LdrResolveDelayLoadsFromDll + 0x1471
0xa2bff: KiUserApcDispatcher + 0xaf
0xa3cfe: __chkstk + 0x12e
0x1e455: RtlFindCharInUnicodeString + 0xa95
0xa2ced: KiUserExceptionDispatcher + 0x2d
0x2a7c: QGQ_WELCOME_SCREEN_DLG::show_welcome_screen + 0x5c
0x8a93: QGQ_APP::init_instance + 0x1f3
0x4c78: msg_exe_fini + 0x58
0x53bc: msg_exe_fini + 0x79c
0x1584: MEM_SEGMENT_INTERNAL::~MEM_SEGMENT_INTERNAL + 0x194
0x5f9f: msg_exe_main + 0x8f
End-trace
Quartus II 64-Bit Version 13.0.1 Build 232 06/12/2013 SJ Web Edition
Service Pack Installed: 1
- Nurina
Can you try to re-install Quartus?
If that doesn't work, please provide the following information:
- Target device
- Machine OS
Nurina
- Nurina
Can you provide some updates?
- Nurina
We do not receive any response from you on the previous question/reply/answer provided. Please login to https://supporttickets.intel.com , view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution, give Kudos and rate 4/5 survey
Nurina
