AEsqu
Contributor
3 years agoHyper-Retiming, How to disable it in the .qsf?
I'm asking because Quartus is not able to apply it on my design, hence I want to skip it to save run time (stratix 10, Quartus 21.1).
Messages from ...
Nurina
3 years agoHello Alex,
Without your design, it will be difficult for me to help you. Is it possible to share through e-mail?
I have checked with the internal team, they have confirmed that your target OPN 1SX280HU2F50E1VG should work with the ASIC_PROTOTYPING_FEATURES qsf.
Can you share the compilation time of before and after adding the set_global_assignment -name ASIC_PROTOTYPING_FEATURES ON qsf setting?
Also, does the compilation report show any reports for retime stage?
Nurina
- AEsqu3 years ago
Contributor
Hi Nurina,
I'm running 2 Quartus jobs with the option ON and OFF for you to compare.
I can already see in the stratix10_fpga_a_mix.flow.rpt that the option is picked:
+---------------------------------------------------------------------- ; Flow Non-Default Global Settings +---------------------------------------+------------+----------------- ; Assignment Name ; Value ; Default Value +---------------------------------------+------------+----------------- ; ALLOW_REGISTER_RETIMING ; Off ; On ; ASIC_PROTOTYPING_FEATURES ; On ; Off ; ASIC_PROTOTYPING_LATCH_SUPPORT ; On ; Off ; ASIC_PROTOTYPING_READBACK_WRITEBACK ; On ; OffI will send by email the reports and .qsf
