AEsqu
Contributor
3 years agoHyper-Retiming, How to disable it in the .qsf?
I'm asking because Quartus is not able to apply it on my design, hence I want to skip it to save run time (stratix 10, Quartus 21.1).
Messages from ...
Nurina
3 years agoHi Alex,
You can disable retiming using this command: https://www.intel.com/content/www/us/en/docs/programmable/683236/22-1/allow-register-retiming.html
Nurina
- AEsqu3 years ago
Contributor
Thank You Nurina, I will test
set_global_assignment –name ALLOW_REGISTER_RETIMING OFF - AEsqu3 years ago
Contributor
The hyper-retimer is still executed after adding
set_global_assignment -name ALLOW_REGISTER_RETIMING OFF
in the .qsf
Note: In the fitter report/ignored assignments report it is not present, so it is taken into account.
Is there another command available to prevent that?
