9 years agoHYPER_RETIMER Error
Hi, Please give some suggestion to solve this error Error (332000): ERROR: Assignment HYPER_RETIMER has multiple values.
9 years agoHello Ak_M,
You have probably found a solution... But I ran into the same issue (also DDR3/Arria10). Commenting part of the generated script instance_name\altera_emif_arch_nf_160\synth\instance_name_altera_emif_arch_nf_160_wyghoeq_pin_map.tcl as follows solved the problem: # with the hyper-retimer, the tdb netlist may contain the full set of routing nodes, so we need # to search deeper # if {[expr [get_global_assignment -name "HYPER_RETIMER"] == "ON"]} { # set var(pll_inclock_search_depth) 250 # set var(pll_outclock_search_depth) 250 # set var(pll_vcoclock_search_depth) 50 # } else { set var(pll_inclock_search_depth) 30 set var(pll_outclock_search_depth) 20 set var(pll_vcoclock_search_depth) 5 # } Of course, this is not ideal as this is a file which gets regenerated. However, from Q16.1 this seems to be fixed.
