9 years agoHYPER_RETIMER Error
Hi, Please give some suggestion to solve this error Error (332000): ERROR: Assignment HYPER_RETIMER has multiple values.
9 years agoYes correct, It has to be FLOW_ENABLE_HYPER_RETIMER_FAST_FORWARD.
I tried to enable and disable HYPER_RETIMER using GUI, but till it gives same error. The error is inside a .sdc of DDR3 controller in qsys block. Error (332000): ERROR: Assignment HYPER_RETIMER has multiple values. Use the "get_all_global_assignments" command to get all values or use the "get_global_assignment -front" command to get the first value. while executing "get_global_assignment -name "HYPER_RETIMER"" (procedure "altera_emif_arch_nf_160_pktenta_get_ddr..." line 9) invoked from within "altera_emif_arch_nf_160_pktenta_get_ddr_pins $instname allpins var" (procedure "altera_emif_arch_nf_160_pktenta_initial..." line 15) invoked from within "altera_emif_arch_nf_160_pktenta_initialize_ddr_db altera_emif_arch_nf_160_pktenta_ddr_db var" invoked from within "if { ! [ info exists altera_emif_arch_nf_160_pktenta_sdc_cache ] } { altera_emif_arch_nf_160_pktenta_init..." (file "../altera_emif_arch_nf_160/synth/altera_emif_arch_nf_160_pktenta.sdc" line 122) And, I'm using Arria 10 FPGA
