16 years ago --- Quote Start --- Simply ALTFP_ADD_SUB can't reduce it's LE requirement to said 400 LEs without omitting a considerable part of it's function, e.g number of calculated bits. So rbugalho obviously assumed, you must have removed part of it's arithmetic function by not completely connecting all in- and outputs of the Megafunction. I agree that it's the only plausible explanation for your results. --- Quote End --- Thanks for your reply, FvM. But how do I check whether I omitted a part of it's function? I just used the .cmp files to instantiate it and assigned all the signals to the Port map. I assigned values to the inputs into the megafunction by code and it manages to calculate the correct result, so I guess it should be functional. Thanks again, Chris
