16 years agoI am facing the exact same problem as kaushalyas.
the bdf file won't compile even if I use the same " param " name as an input to some symbol, even if I match the correct bit-widths of input & param. Same problem with using the " constant " symbol inside bdf file. Can anybody explain how to use these two symbols (param & constant) as direct inputs to some other block ? Or can't we ?
