16 years agoHi OliB.Good,
Thanks for your reply. Please check my attachment. Its somewhat similar to what you have done. I have used the PARAM to define a generic 8 bit constant and tried to route it to an 8 bit input port of a module in the same BDF. I named the input bus the same as the PARAM name with the index. But when I try to convert it to HDL just to check my idea has worked, it generates wrong HDL. Pls let me know if your design has correctly being generated in HDL. Thanks and regards, kaushalyas
