11 years ago --- Quote Start --- You make another 'helper' IP core. Essentially create a Verilog of VHDL file like:
module pio_helper(
input pio1,
output piomerge
assign piomerge = pio1;
endmodule
Make a new component in Qsys using that module, and connect all your pio controllers to it. Then export the larger merged output from your Qsys system. --- Quote End --- Hi TCWORLD, I have made the code so that only ONE line coming out from the vhdl block pio[1..10][1..12] , but in the Nios II symbol generated by Qsys, I can't make it 2D, so I have 12 lines, pio[1][1..12], pio[2][1..12] until pio[10][1..12]... what should I do next so that I will only have ONE line from Nios II symbol?? As mentioned in your post, I have already created a .vhdl file as follows: entity pio_helper is port( pio1 : in std_logic_vector(11 downto 0); pio2 : in std_logic_vector(11 downto 0); pio3 : in std_logic_vector(11 downto 0); pio4 : in std_logic_vector(11 downto 0); pio5 : in std_logic_vector(11 downto 0); pio6 : in std_logic_vector(11 downto 0); pio7 : in std_logic_vector(11 downto 0); pio8 : in std_logic_vector(11 downto 0); pio9 : in std_logic_vector(11 downto 0); pio10 : in std_logic_vector(11 downto 0); pio11 : in std_logic_vector(11 downto 0); pio12 : in std_logic_vector(11 downto 0); piomerge : out std_logic_vector(143 downto 0) ); end pio_helper; architecture behavior of pio_helper is begin piomerge(11 downto 0) <= pio1; piomerge(23 downto 12) <= pio2; piomerge(35 downto 24) <= pio3; piomerge(47 downto 36) <= pio4; piomerge(59 downto 48) <= pio5; piomerge(71 downto 60) <= pio6; piomerge(83 downto 72) <= pio7; piomerge(95 downto 84) <= pio8; piomerge(107 downto 96) <= pio9; piomerge(119 downto 108) <= pio10; piomerge(131 downto 120) <= pio11; piomerge(143 downto 132) <= pio12; end behavior; I have created a new component in Qsys using this pio_helper.vhd file, My question is, how do I access each pio1, pio2...pio12 etc in C code? since conduit component is not assigned base address?
