11 years ago --- Quote Start --- The simplest way is to have a vector which is pio[0:119]. Where every port starts at a 12 bit offset. I'm pretty sure Qsys doesn't allow its connections to be 2D so while you can do it in SystemVerilog and VHDL, Qsys couldn't generate the system. --- Quote End --- TCWORLD, thank you for your reply. At the VHDL side, I have no problem to make it vector. Forgive me, I don't understand how to set pio[0:119] in Qsys as I can only set a maximum of 32 bits for each pio in Qsys, please could you explain in details how I could achieve pio[0:119]? Thank you in advance.
