9 years agoHow to utilize programmable delay chain?
Greetings, I'm using a Cyclone IV, and I have a bi-directional DDR data strobe line that I am using to clock in data (clock in when I'm performing a read. I am basically using this documen...
9 years agoI didn't change the .sdc. (Or I did, it failed, and I changed it back). For DQS strobe you do need the same edge capture, so what I tried wouldn't work anyway. The only changes I made then are the HDL attributes and location constraint, which got it to meet timing.
That app note may be using specific hardware for DQDQS and require a megafunction. I'm not sure. I was just trying to close timing using the regular stuff.
