If the VQM netlist is your top file please add it to the files list in QII eventually assign a pinout and run a full compilation.
If the VQM netlist is component of your full project, instantiate the component in your project and add the VQM netlist to the file list in QII Kind Regards Pietro - Altera_Forum
Hi Pbaradel,
Do you mean that add the xxx.vqm and xxx.qsf to xxx project and take a full compilation? By the way, if the design consists some megawizard ip cores such as gxb transceiver channels, how to synthesis the design to get over error message indicated by Synplify that some modules related to gxb channels could not be found? Thanks for help.
