AZahe1
6 years agoHow to use the SCLR port of a flip flop in VHDL?
I am new in VHDL and the Quartus software. I was designing a simple flip flop circuit with synchronous clear by using sequential VHDL, but in the RTL schematic, it looks like it added a multipl...
sstrell
6 years agosclr is active high, so your if check should be if sclr = '1'. Also, there's no need for the extra qs signal. Just make the assignments to q in the process.
#iwork4intel
- AZahe16 years ago
thank you for replying.
I changed the reset to be active high, but it still uses extra logic. the only difference is that the inputs of the multiplexers have flipped.
yes right, I too think there is no need for the qs signal here.
