JKastil
7 years agoHow to use several versions of custom component in Platform Designer at once?
I have following situation: There is main QSYS system (main.qsys) which contains several subsystems (PCIExpres.qsys, video_transparency.qsys, picture_blend.qsys, processor_subsystem.qsys, video_grab...
sstrell
7 years agoWhen you create a component using the Component Editor, there is a version field on the first tab of the tool. Set the version number and point to the appropriate file(s) for that version on the Files tab. Then, when you add the component to a system, right click it in the IP Catalog and choose to add the appropriate version to the system design.
