10 years agohow to use set false path properly to constrain clocks in different clock domains
IN my project, I have two different clock domains.One is CLK_In_50MHz from oscillator outside. The other is ADC_CLK,48MHz,which is the DCO output clock of an ADC. Then I generate a pll,named PLL_ADC ...
10 years agoderive_pll_clocks command can constrain all pll output clocks. Do I need to add the pll clocks on another group?
