13 years agoOK, in that case I try to double my arrays. The writing process must then write two arrays with the same data and then I use one Array for reading process 1 and the other array for reading process 2.
This will double the needed size of M9K, but that is not my problem. My Problem are the Logic Elements. And when I get the arrays by this way into the Memory, well, problem fixed. Thank you, I will post the result.
