How to Use LPM_FF(DFF, INV..etc) from Insert Symbol in quartus prime? How to add this mega-function libraries.
Explain in detail steps.
below are steps are done
LIBRARY lpm;
USE lpm.lpm_components.all;
still error
Error (10346): VHDL error at lpm_inv_0.vhd(43): formal port or parameter "LPM_WIDTH" must have actual or default value
Error (10784): HDL error at lpm_pack.vhd(219): see declaration for object "LPM_WIDTH"
- Vicky1
Please modify the symbol properties & compile again,
Right Click on symbol(LPM_DFF)-> properties-> Parameter as shown below,
if this has not resolved then provide bit more information like,
- Quartus edition(Lite/Pro/Std) & Version used
- Device part number used
- Elaborate about, what exactly you are trying?
Vicky
- Vicky1
Have you resolved the issue?
Should I consider that case to be closed?
Vicky
- Vicky1
Please refer the attached screenshot & try at your end.
please let me know if you have any different concern.
Vicky
- BDE
Symbol synthesis will work,
Can you try to convert the same symbol to VHDL and synthesis.
regards,
Balakrishna
- Vicky1
Hi Balakrishna,
After successfully synthesis(my last post) , instantiate it in top module like below,
- Open .bdf file
- File-> Create/Update->Create VHDL component declaration component files for current file(It will create .cmp file)
- Open that .cmp file & instantiate it in top module & then compile that top module.
Vicky
