MBier
7 years agoHow to use IOWR and IORD functions
Hello, I'm building simple custom component and actually trying to start it up but in eclipse any function work. Have you any ideas where the problem is ? I attached code and screens from eclipse. ...
Abe
7 years agoIs the custom component connected to the NIOS CPU in your design? If so, check the base address for the custom component. In Eclipse, make sure to enable the small C libraries in the BSP editor when creating the project.
You can use the IOR/IOW commands to write to your custom component via the NIOS-2 CPU address space and offset.
