BSusi
7 years agoHow to use ekp as persistent master key on MAX 10.
I've tried to develop a secure FPGA environment with master key (8.ekp) and encrypted ROM image (*.pof). The idea is to program the master key once before the FPGA left to the customer and the (*.pof...
JohnT_Altera
7 years agoHi,
- Is the EKP which stored in ICB secure? I see that there's not possible to retrieve the key via JTAG programmer.
Yes. You can either write or erase. No read is possible.
- Is it also protected from being read? I suppose that the EKP is stored in an unencrypted manner in the ICB.
Yes.
- I see that based on this document https://www.intel.com/content/www/us/en/programmable/documentation/bhc1410500804155.html#bhc1410500737675 in the part of Non-Volatile and Volatile Key Storage, the possibility to program an OTP hardware key (for 20nm FPGAs) is mentioned. Is this the case also for MAX 10 devices? I use 10M04SCM153C8G to be specific.
Max 10 does not support this.
