10 years agohow to use clk in fsm
hey..I want to build a final state machine embodies eight numbers and then she proceeded to tell the eighth.For example if the eight number is four I want the machine extract four pulses of 1 cloc...
10 years agoYou have to define state transition more clever. <- the problem begins here. Try write down it on the notebook paper or/and use builtin FSM tool in Quartus.
Then you command your FSM to saty in state in which it will pulse-out. It is good if you use counter which counts down to zero each clock cycle and you allow the clock signal to go trough "clever" AND-gate to pulse-out.
