14 years agoHow to use Avalon-MM Master BFM?
Hello, all. I want to use Avalon Verification IP Suite to check a Qsys custom componet, which have an Avalon salve interface and a Avalon conduit interface connecting a LSI. I wrote this p...
12 years ago --- Quote Start --- i tried what you mentioned in your post# 24 --- Quote End --- Why oh why can you not read!? Post# 24 refers to a question about getting things to work in Quartus 13.1. You have indicated that you are using Quartus 11.1sp1 which is what the tutorial I linked to in# 39 was written using. Are you reading through the PDF linked to on the Wiki tutorial??? *JUST READ THE TUTORIAL* Ignore any of the discussion in this thread, as it relates to Quartus 13.1. If you install Quartus 13.1, then qsys_vip.zip will work fine. Cheers, Dave
