14 years agoHow to use Avalon-MM Master BFM?
Hello, all. I want to use Avalon Verification IP Suite to check a Qsys custom componet, which have an Avalon salve interface and a Avalon conduit interface connecting a LSI. I wrote this p...
12 years ago --- Quote Start --- For my previous post, I couldn't get the solution given by david for joel working as my model sim is only 6.5 version. I'Ll download the latest and try the solution. --- Quote End --- You cannot mix-and-match. If you are using Quartus 13.1 to generate the code, then you *HAVE* to use the same version of Modelsim as shipped with that version, whether it is the Altera Starter Edition, or full Modelsim-SE edition. I've had cases where models do not work correctly when mixing tool versions; its best to stick with the combination verified by Altera. Cheers, Dave
