14 years agoHow to use Avalon-MM Master BFM?
Hello, all. I want to use Avalon Verification IP Suite to check a Qsys custom componet, which have an Avalon salve interface and a Avalon conduit interface connecting a LSI. I wrote this p...
12 years agoThe attached file contains a Qsys system with an Avalon-MM Master BFM and an Avalon-MM Slave BFM. The testbench uses the Master BFM to issue single write/read and burst write/read transactions to the Slave BFM.
The readme.txt file describes how to build the system from scratch using Quartus and Qsys, and then indicates the edits that need to be made to the Modelsim simulation script (msim_setup.tcl) to simulate the top-level testbench. The readme.txt file indicates the differences between Quartus 12.1sp1 and Quartus 13.1. The Modelsim setup script is much better under Quartus 13.1 (less edits required). Cheers, Dave
