14 years agoHow to use Avalon-MM Master BFM?
Hello, all. I want to use Avalon Verification IP Suite to check a Qsys custom componet, which have an Avalon salve interface and a Avalon conduit interface connecting a LSI. I wrote this p...
13 years ago --- Quote Start --- What am I doing wrong? --- Quote End --- I'm not sure. I have not used the Slave BFMs, so I do not have an example that I can compare your code to. I'd recommend starting with working code from an Altera example, and then modifying it to suit your needs until you track the error down. My guess is that you have not initialized the model correctly. The above Master BFM tests only work correctly because earlier in the main body of the code the Master BFM was initialized. Cheers, Dave
