14 years agoHow to use Avalon-MM Master BFM?
Hello, all. I want to use Avalon Verification IP Suite to check a Qsys custom componet, which have an Avalon salve interface and a Avalon conduit interface connecting a LSI. I wrote this p...
13 years ago --- Quote Start --- I solved this problem. I cleaned my simulation project, generated everything once again and added to my read task these two lines: wait(tb.simulation_inst.mm_master_bfm_0.signal_response_complete); tb.simulation_inst.mm_master_bfm_0.pop_response(); Now everything runs as expected :) --- Quote End --- Great! The error sounded like it was due to an object being reused before the underlying library was finished with it, so this wait makes sense. Thanks for posting your solution. Cheers, Dave
