13 years agoI believe you simply need to "Generate" your system again in order to copy your latest HDL files. If you are modifying the _hw.tcl as well, you would need to File->Refresh prior to that.
The Qsys command line executables are covered in the qsys_intro.pdf, search for "ip-generate". If your HDL+_hw.tcl code is relatively simple, you can also simply copy the HDL files to the synthesis/submodules/ directory manually or as part of a script.
