How to tell timing closure is achieved? How to create real timing constraints?
Here is the output from the compilation report.
I don't see anything indicating a timing violation.
The design runs off a single master clock.
The spi port is a master and generates a spi clock and the external slave will transfer valid data as long as it reads and writes data on the correct clock edge.
The Manchester encoder/decoder looks for transitions in the data and counts 1/2 bit from the last transition to detect whether the bit is a 0 or 1 and recover the clock which is always in the middle of the bit. This seems like something that should be described by a virtual clock that I've read about in the apnotes but I'm not sure how to do this.
Are the input and output delays I'm using correct for a Max 10?
Should the spi clock be described by a generated clock?
Info: *******************************************************************
Info: Running Quartus II 64-Bit TimeQuest Timing Analyzer
Info: Version 14.0.2 Build 209 09/17/2014 SJ Web Edition
Info: Processing started: Wed Nov 28 12:30:52 2018
Info: Command: quartus_sta top_IPFE_Podcom -c top_IPFE_Podcom
Info: qsta_default_script.tcl version: #1
Info (11104): Parallel Compilation has detected 4 hyper-threaded processors. However, the extra hyper-threaded processors will not be used by default. Parallel Compilation will use 2 of the 2 physical processors detected instead.
Info (21076): Core supply voltage operating condition is not set. Assuming a default value of '1.2V'.
Info (21077): Low junction temperature is 0 degrees C
Info (21077): High junction temperature is 85 degrees C
Info (332104): Reading SDC File: 'SDC1_edited_111618.sdc'
Info (332151): Clock uncertainty is not calculated until you update the timing netlist.
Info (332123): Deriving Clock Uncertainty. Please refer to report_sdc in TimeQuest to see clock uncertainties.
Info: Found TIMEQUEST_REPORT_SCRIPT_INCLUDE_DEFAULT_ANALYSIS = ON
Info: Analyzing Slow 1200mV 85C Model
Info: Can't run Report Timing Closure Recommendations. The current device family is not supported.
Info (332146): Worst-case setup slack is 32.502
Info (332119): Slack End Point TNS Clock
Info (332119): ========= =================== =====================
Info (332119): 32.502 0.000 clk_in
Info (332146): Worst-case hold slack is 0.458
Info (332119): 0.458 0.000 clk_in
Info (332146): Worst-case recovery slack is 36.855
Info (332119): 36.855 0.000 clk_in
Info (332146): Worst-case removal slack is 42.329
Info (332119): 42.329 0.000 clk_in
Info (332146): Worst-case minimum pulse width slack is 40.450
Info (332119): 40.450 0.000 clk_in
Info (332001): The selected device family is not supported by the report_metastability command.
Info: Analyzing Slow 1200mV 0C Model
Info (334003): Started post-fitting delay annotation
Warning (12535): Advance timing characteristics for device 10M08SAU169C8GES
Info (334004): Delay annotation completed successfully
Info (332146): Worst-case setup slack is 33.072
Info (332119): 33.072 0.000 clk_in
Info (332146): Worst-case hold slack is 0.411
Info (332119): 0.411 0.000 clk_in
Info (332146): Worst-case recovery slack is 37.011
Info (332119): 37.011 0.000 clk_in
Info (332146): Worst-case removal slack is 42.177
Info (332119): 42.177 0.000 clk_in
Info (332146): Worst-case minimum pulse width slack is 40.438
Info (332119): 40.438 0.000 clk_in
Info: Analyzing Fast 1200mV 0C Model
Info (332146): Worst-case setup slack is 35.455
Info (332119): 35.455 0.000 clk_in
Info (332146): Worst-case hold slack is 0.150
Info (332119): 0.150 0.000 clk_in
Info (332146): Worst-case recovery slack is 39.491
Info (332119): 39.491 0.000 clk_in
Info (332146): Worst-case removal slack is 40.893
Info (332119): 40.893 0.000 clk_in
Info (332146): Worst-case minimum pulse width slack is 40.087
Info (332119): 40.087 0.000 clk_in
Info (332101): Design is fully constrained for setup requirements
Info (332101): Design is fully constrained for hold requirements
Info: Quartus II 64-Bit TimeQuest Timing Analyzer was successful. 0 errors, 1 warning
Info: Peak virtual memory: 508 megabytes
Info: Processing ended: Wed Nov 28 12:30:54 2018
Info: Elapsed time: 00:00:02
Info: Total CPU time (on all processors): 00:00:03
